I want to enable Other selection based on answer to previous question. I can get Other selection to show up on one response but if a different answer to that previous question is selected, the Other selection is not an option.
Works: Safety (Lifeline) - Law Enforcement (Component) - Unsafe/Multi-Agency, Other (Indicator choices) - Text (text box opens when user chooses Other
Does not work: Safety (Lifeline) - Fire Service (Component) - Unsafe Conditions, Response Needed (Indicator Choice) Other selection is not an option
Does not work: Safety (Lifeline) - Search & Rescue (Component) - SAR Response (Indicator Choice) Other selection is not an option
It would seem the component column needs to be formatted differently.
I feel like component column needs to be formatted differently. Fire Service and Search & Rescue needs to be added but how do I make that call so it takes in the survey?
Hello @dwold,
I'm guessing selected() isn't playing nice with the choice names, I switched the choice filter to use the regex() function and that's working. I've attached an XLSForm for reference
Hello @dwold,
For the other choice in the component column you can comma separate all the components (ex. Law Enforcement / Security,Fire Service,Search & Rescue) then use the selected() function in your choice filter column. The choice filter would look like selected(${Component}, component).
Hi @ZacharySutherby thanks for the response! I tried those steps but unfortunately, I still cannot get that action to work. The other selection went away in the Indicator field for every Component drop-down selection noted in column E/component
pic8.png Do you see any missteps that I took in my table?
Survey results:
Hello @dwold,
The selected() function would go in the choice filter for the Indicator question not the IndicatorOther question.
I should add I tried keeping the ${Indicator}='Other" in the relevant column (N) and removing it. Neither had any effect on the survey
@ZacharySutherby Does this look right? Other option still being omitted.
Thanks for your assistance.
Hello @dwold,
@ZacharySutherby it is working on my end too. Thank you for all your help with this, I appreciate it.
