Count how many times a choice is used.
931
03-28-2019 01:42 PM
markcain
I'm trying to count the number of times a choice has been selected across many select_one questions.
as an example
The count works when only one instance is chosen, but fails to add values.
I realise this is due to the use of the 'if' statement as a control.
However if i use
if(selected(${firstchoice,'a') and selected(${secondchoice},'a'),2,if(selected(${firstchoice},'a') or selected(${secondchoice},'a'),1,0) it does work. (used for option 'c' above)
This solution is okay if there are only 2 options, however I want to count the number across 23 questions and the if statement would have 100's of permutations to enter.
There must be a better way.
I have tried using hidden fields as variable to hold the count, which doesn't work, (as in the first note field above), but i cant get the addition to work.
I have tried using countif but that is not a recognised function, and count(selected()) only works across multiple selects which is not an option for my audit
Any ideas?
markcain
I've solved it...
simply used an if statement to assess which option is selected then added up each answer
if(selected(${firstchoice},'a'),1,0)+if(selected(${secondchoice},'a'),1,0)
if(selected(${firstchoice},'b'),1,0)+if(selected(${secondchoice},'b'),1,0)
if(selected(${firstchoice},'c'),1,0)+if(selected(${secondchoice},'c'),1,0)
rookie mistake.....tried to over complicate it
markcain
I've solved it...
