Coordinates Saved from Null Geopoint Instead of Non-Null Geopoint
10920
14
02-10-2021 01:52 PM
SkylerKasko
I have a survey form with two geopoint questions. The first has bind::esri:fieldType set to null, and the second has the fieldType left blank. When the survey is submitted, I would expect the coordinates saved as the feature's center, e.g. the point that shows up one a web map, to come from the second Geopoint. Instead, when I submit the survey, it always shows up in the web map at the coordinates of the first, null, geopoint.
I have attached a minimal example: an XLSForm with only two questions, null_geopoint and saved_geopoint. As explained above, the feature produced when the survey is submitted appears at the coordinates provided for null_geopoint, rather than at the coordinates provided for saved_geopoint.
I can fix this by switching the order of the questions. So, it appears that the survey is always saving the coordinates of the first geopoint question, rather than the expected behavior of saving the coordinates of the non-null geopoint question. In the actual survey I am working on, through, it is not feasible to switch the order of the questions. Is there a way to get Survey123 to save coordinates of a geopoint question that is not first as its center?
I'm publishing the survey with Survey123 Connect version 3.11.123 and submitting it with the field app version 3.11.164.
Thanks, Sky
SkylerKasko
Hi @Anonymous User,
I logged the bug via the Esri Support site. I do not have a record of receiving any email or correspondence after submitting the bug.
Best, Sky
by Anonymous User
Not applicable
Hi @SkylerKasko,
I would suggest you contact Esri Support to follow up, as for me to look into it further I would need a case id or BUG number?
Regards,
Phil.
SkylerKasko
OK, thanks for the suggestion to contact Esri Support. I cannot provide you with a BUG number, unfortunately, as the entire point of this discussion was to discover what the BUG number was.
Best, Sky
DuncanKinnear
Hey, just wondering if this has got any further?
I have the same issue, where I'd like my child point features to default to the parent location, apart from certain site types where I'd like the user to be able to update the child location. I can get around this by having the child geopoint visible on all site types, but the more elegant solution would be to have a null geopoint in the background to do a calculation, which currently doesn't work. Or is it possible to control visibility of a geopoint question based on previous answers?
Cheers
Duncan
SkylerKasko
I'm not aware of any developments on this, but depending on the details of your form one possibility may be to put the null geopoint you're using for the calculation later in the form than the geopoint you're using it to calculate. For an example, see: https://community.esri.com/t5/arcgis-survey123-questions/save-location-with-offset/m-p/1154967/highl...
