Continued issues with pulldata in web forms
1872
11
08-20-2018 01:56 PM
WetherbeeDorshow
I used the sample called "Calculate Location from CSV", modifying the sample slightly to point to an updated pulldata table and to use different field names. I still get the error:  FormLogicError: instance "lift_locations" does not exist in model. I attached the survey and the pulldata table. Thanks for the help.
KathrynLevy1
Could you post the form with the correct calculation structure? I am having the same issue and would like to see how you resolved it in the xlxs form.
WetherbeeDorshow
I have attached the form and the pulldata table. Best of luck.
