Hi Everyone,
I'm trying to construct the geometry as an answer for a geoshape feature using the calculate field, and am running into some difficulties.
Firstly I am performing a pulldata @layer getRecordAt request from an AGOL polygon feature layer:
pulldata("@layer", "getRecordAt", "${polygon_feature}", ${Address_activity_location})
and was then using @json calculation to extract the geometry attribute and populate the geoshape this way
"" + string(pulldata("@json",${geometry_query},"geometry"))
[I've tried multiple iterations of the above calculation with and without the "" + string but have only gotten it working in Survey123 Connect and not via the published survey. I have also increased bind::esri:fieldLength to 50000 to capture all of the coordinates and aim to reduce precision in the query when it's working]
I end up with the polygon geometry as the answer:
"pcode_polygon": {
"rings": [
80.2224833796995,
7.52764666203902
80.2227977900489,
7.5276021333672
........... etc...
and when used to populate the geoshape in Survey123 Connect, this works and displays the geometry correctly, but it doesn't when published to Survey123 and real records are submitted in the survey. The geometry appears empty.
I've since discovered the appropriate format for constructing geoshape/geotrace is:
Individual vertices that make up the answer to a geotrace or geoshape question are space-separated sets of latitude and longitude values (in decimal degrees) separated by a semicolon.
-37.842156723211474 144.95942945338243; -37.83554486071995 144.9726235713864; -37.85681405373047 144.98240735651922; -37.85954045531896 144.97715349053766
I think I could construct the geometry were I able to perform find/replace style regex against "geometry.rings" , but can only seem to find a way to use regex to apply constraints.
Are there any ways to construct appropriate geometry from the existing geometry data? Or is there some simpler construct / copy geometry operation available to perform this that would be more appropriate?
Thanks!
Hello @DeanMoiler_MapAction,
You should be able to use sum(string(pulldata("@json",${geometry_query},"geometry"))). The Query a Feature Layer sample available in Connect demonstrates how to calculate a geoshape question based on geometry returned from a feature service.
Where does one find this "Query a Feature Layer sample available in Connect" ??
Hello @mikaël,
Open ArcGIS Survey123 Connect, select the New survey icon on the top left, log into your ArcGIS organization if not already, in the pop up under the Esri section select Samples, in the search bar you can enter Query a Feature Layer which will filter the list to just the one sample.
I you do not see the Esri section in the pop up you or your organization administrator will need to go to the Organization settings in the Survey123 website and enable Templates and samples from Esri.
Yes thank you so much!!!
Finally managed to generate polygon from feature service.
We'd like to capture a Taxlot shape from a Hosted Feature Service on AGOL via the Survey 123 App.
The Taxlot shape would be the Parent record.
Inspectors then collect Test Points within the Taxlot.
I consider these to be the Child records.
The idea is to use the Taxlot Shape as the Site or Location.
The Shape would have attributes like Owner, Taxlot Number, and Acres.
The Test Points would have data specific to the points.
Once data is collected.
A User can then Zoom to the Parent shape, to see the Child points within the shape.
Can you please help with achieving this?
It seems what you are doing here should work.
Thank you in advance,
Aaron
Hi @ZacharySutherby,
That was very helpful, thank you for this and apologies for the delayed response! I did manage to find this sample separately (somewhere) online, but I couldn't get it to submit geometry records (always loading gif displays) so I thought it was just an old sample. From the looks the problem is caused due to difference between browser submission vs app submission of surveys.
I didn't realise that this workflow does not work (and I think I ready somewhere it is not currently supported?) when surveys are completed in the browser, and only returns geometry when using the survey123 app. I have seen this documented somewhere, but have not been able to find it again!
I had it working in survey123 connect a long time ago, but could never get it to work when submitting in the browser app. I never even though to test submission in the survey123 app itself. One to keep in mind in future.
Needing the app installed to submit surveys does hamper the workflow I'm trying to achieve where I would hope to make the survey accessible to different aid organisations that would not have ArcGIS Survey123 app installed, and probably wouldn't have the option to install when in the field. This would mean duplication of
Q: Is there any likelihood that the geometry extraction capability will be made possible via the web browser submission rather than just survey123 app, or have I gotten something completely wrong and it should be possible?
Thanks!
Dean
Can the shape then be displayed?
Either through the geometry within JSON or other.
Can this be done by selecting a Taxlot Hosted Feature Service as the Polygons, via the Survey123 app?
Should I be using Field Maps instead?
In the end.
We want a Shape as the Parent and Points within the Shape as the Children.
Then we want to Zoom to the Shape, to see the Shape, and the Points.
I am using pulldata('csv', 'SHAPE', 'name', ${name}) (from csv not url)to get my geometry and then sum(${calc_field}) to get calculate my geometry.
This doesn't seem to work, do I need to convert the geometry into a Json value first? I feel like it should be working based on the sample.
Edit: The spatial reference was different.
What is the purpose of the sum() function? I am needing to add this to a repeat but the sum() is causing issues. Is it possible to use sum(string(pulldata("@json",${geometry_query},"geometry"))) without sum()?
