Constraints: Requiring integer response to be >= A Prior Response
733
02-14-2023 03:04 PM
RichardPasquale
Can you code constraint field to ensure an integer value response is equal to or greater than a prior integer response?
Or, is there another way of making sure the intiger response for "diameter of large end" is => the small end?
ZacharySutherby
Hello @RichardPasquale
To set up the constraint you would use . >= ${small_end}. The period or dot represents the current input for the question.
Please see this documentation for more information: https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformformulas.htm#ESRI_SECTION1_8979CBF...
Thank you,
Zach
ZacharySutherby
Thank you,
Zach
