Correct I think I was the one that posted for them to remove the checks when a field is hidden. The reason was if it does fire then it highlights a part of the form in red but there is no question there or it is the question above it I foget. Makes it confusing on the user since it just sits there and no way to really fix it.
I just leave the list for the user so they can see what they all collected so far. Does not seem to hurt anything just takes up a little space. We made it a group and collapse it so it is out of the way.
Also note in some forms in the newer 123 I had to add a check for the first record. It seems to load in a different order now. I do not get it in all forms just some depending on relevants. I also updated it to add the comma in the check. We had some rare plant codes that broke it. Like EAP was getting confused with EAP2. So now it checks for EAP,
New formula is weird to look at Unknown is my exception
if(${TempCountUnk}=0, 1,${UnknownCode}='' or contains(${UnknownCode}, "XXXX") or not(contains(${AllUnknownCheck}+",",${UnknownCode}+",")))
Uses a temp count like this
Other forms I can still use this but had to add a check for blank otherwise it fired too quick i think.
${Species}='' or contains(${Species}, "XXXX") or not(contains(substr(${AllPlantsCheck}, 0, string-length(${AllPlantsCheck}) - 3), ${Species}))
Hope that helps
