Constraining an Integer to Negative Values
1710
07-28-2020 11:15 AM
MichaelStroh
I am trying to constrain input values for an integer type question to less than or equal to zero values only.  I entered
".<=0" into the constraint field, but it does not seem to work.
Jim-Moore
Hi Michael
Your syntax looks correct; I just tested with the following and the constraint worked as expected:
Please note that the constraint (and its message) is only triggered when the survey is submitted.
Best,
Jim
MichaelStroh
Thanks Jim.  I was expecting it to be applied as soon as the user entered the value.
Jim-Moore
Hi Michael, this is something that has been raised a few times on GeoNet and there are a couple of ArcGIS Ideas you can vote for and/or add your comments to. Please see:
Constraint messages to show up on the fly
https://community.esri.com/ideas/17633
