Consolidating data from 11 surveys into a feature service to create a unified report
817
01-05-2024 01:22 AM
IngaLPetersen
The challenge involves consolidating data from 11 surveys conducted by various fieldworkers into a unified report.
The objective is to derive a percentage of correct answers by aggregating positive and negative scores from all 11 surveys. In my exploration of the Survey123 documentation, I have been unable to find a clear and straightforward method for combining all results from the feature services to generate a single report.
Can this be done?
Any assistance or insights  would be greatly appreciated.
abureaux
MVP Frequent Contributor
I'm assuming you are looking for the Summary Section? Not something I typically use, so I can't really help with setting it up, but the blog should give you enough info to determine if that is what you need or not.
Is a Summary Section wont work for you, then you will need to look into other less simple solutions.
