Conditional questions error
4270
01-26-2022 12:29 PM
AliciaShyu
I'm following the instructions to create subsequent conditional questions https://support.esri.com/en/Technical-Article/000022505, and I'm getting the following error:
Error converting XLSForm
There has been a program trying to replace ${rating} with the XPath to the survey element name 'rating'. There is no survey element with this name.
rating is in the "choices" tab. Enclosed is the XLS form; any pointers will be helpful. Thanks!
Tags (1)
3 Solutions
GeoJosh
Alicia,
The name of the question should be referenced in the "${}", not the name of the choice list. See the attached xlsx.
Josh
AliciaShyu
Thanks Josh, that worked!
Quick question, my commercial or residential question doesn't work. It only shows commercial. I' ve tried changing the appearance to minimal and regular horizontal but that didn't work either. Could you please see if you're getting the same issue? Thanks.
JayantaPoddar
In Choices tab, A13 is empty. Please fill with appropriate value as shown below.
Think Location
GeoJosh
Alicia,
Josh
AliciaShyu
JayantaPoddar
Think Location
AliciaShyu
Thanks Jayanta!
