Concatenation of text, date and number fields
7452
5
10-23-2019 12:39 AM
by Anonymous User
Not applicable
Is it possible to concatenate two or more fields with date, text and number types in Survy123. I havent seen any example.
DougBrowning
Did you try to cast it
string(question or value)
Converts to string. Conversion varies depending on data type.
string({$question_one})
by Anonymous User
Not applicable
Hi Doug,
Not going to only cast, I have about 3 or 4 fields with different types, date, number and text and want to concatenate it into one field.
DougBrowning
Yea that is what casting is.
string(${yournumberfield}) + ${yourstringfield} + string(${yourdatefield})
or
concat(string(${yournumberfield}), ${yourstringfield}, string(${yourdatefield}))
by Anonymous User
Not applicable
Hi Doug,
Many thanks. but couldn't resolved date field. for the date field it gives a number like 1570347000000 and I want it in a format like 20191028.
I used string(${field_0}+${field_6}+${field_3}). the type for field_0 is date.
DougBrowning
Check out this page for things like  format-date(${WSDateTime},'%H:%M')
https://community.esri.com/groups/survey123/blog/2016/04/17/dates-and-time-in-survey123-for-arcgis
