Complex calculations in a Repeat
1307
04-16-2025 11:02 AM
Phein62
I'm using Survey123 Connect, v. 3.22.53.  I have repeats in my survey -- based on the Advanced Template -- where I collect information on concrete surface abnormalities, including type (cracking, spalling, etc), length in inches, and recommended action (monitor, repair, no action).
I can get the sum of all the lengths for each entry in this repeat by creating a group outside of the repeat that references named fields from within the repeat, e.g.:
begin group            Summary            Summary of Cracks
decimal                     TotalLength       Total Length of Cracks                 sum(${Length})
end group
The repeat looks something like:
begin repeat        Surface                      Surface Condition
begin group         Surface1                      </>
decimal                  Length                     Length
select_one           DamageType           Type             [NOTE:  This would be cracking, spalling, etc.]
select_one           Recommendation    Recommendation   [NOTE: This would be Monitor, Repair, No Action]
end group
end repeat
What I need to be able to do is get the sum of cracks based on which type of abnormality it is, that is, I only want to include the length of cracks, not the length of spalling, and only those recommended for repairs, not the ones where the recommendation is monitor or no action.
Neal_t_k
MVP Regular Contributor
You can achieve this by creating a hidden field inside the repeat that captures the length only for cracking and only when repairs are recommended. Then sum that field outside the repeat.
decimal                     TotalLength       Total Length of Cracks                 sum(${CrackLength})
end group
hidden                   CrackLength                 Calculation: if(selected(${DamageType},'cracking') and selected(${Recommendation},'Repair'),${Length},0)           bind::type: decimal
end group
end repeat
Neal_t_k
end group
end group
end repeat
Phein62
Thank you very much!   Worked like a charm, and I can see other uses for that syntax.
Phein62
Thank you so very much! I'm going to print this and pin it to my bulletin board.
