Choosing time slot in Survey123 Connect
1627
01-28-2021 11:54 AM
TahirTamba1
Hi all,
I'm trying to set up a question in Survey123 Connect that allows me to choose a time slot to determine two shifts. A day shift and a night shift. The day shift, in this case, begins at 12:00 p.m. and ends at 00:00 a.m., while the evening shift starts at 00:00 a.m. and ends at 12:00 p.m.
Is there a way to configure these time slots in the Survey123 Connect form so that I can automatically select the current shift based on the time of day?
Thank you in advance for your answers and suggestions!
Regards,
2 Solutions
IsmaelChivite
Esri Notable Contributor
Yes. In Survey123 Connect check the Airfield Sample. The shift is calculated automatically based on the current time.
TahirTamba1
Hi Ismael,
Thank again, my issue has been resolved and the Daily Airport Inspection template works fine...
Best regards,
IsmaelChivite
TahirTamba1
Thank you Ismael,
I go right away have a look of this example in the community template.
¡Muchas gracias Caballero!
TahirTamba1
Hi, Ismael,
I think you pointed me to the right answer to solve my problem. Let me test it and I'll get back to you.
Regards,
TahirTamba1
Hi Ismael,
Best regards,
