Character issues (unicode)
1028
05-09-2022 09:20 AM
GaryBowles1
Not sure if this is a Survey123 issue or a general esri issue or an OS issue but when we have a text field in a survey and someone enters a character ie. ", it looks fine in the survey, but when we pull this info into an email notification via GeoEvent Server, the character looks like �.
What is the cause of this? Is there a way to prevent this from happening?
--gary
ZacharySutherby
Hello @GaryBowles1
If the character displays correctly in Survey123 and the Data tab of the feature service the issue may be on the GeoEvent side. It may be best to post to the GeoEvent question board or reach out to Esri Technical Support
Thank you,
Zach
