change visual field width ?
1860
01-11-2022 06:50 AM
GregoireCatineau
Hello,
I have a field for a number but I don't want it to take up all the space on the same row.
Is it possible to change the visual width of the field? Maybe in javascript? I would like a small field for my number ...
thanks in advance
3 Solutions
Katie_Clark
MVP Regular Contributor
Grégoire,
As far as I know, you can't customize the interface to that extent with coding. However, maybe the grid theme could get you to something similar?
https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-groups-grids-and/b...
Best,
Katie
If this post helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
DougBrowning
MVP Esteemed Contributor
GregoireCatineau
thanks you two. We can wait until this fonctionnality
Katie_Clark
Grégoire,
Best,
Katie
DougBrowning
Only way I know it to use a grid.  You may not like the look  https://community.esri.com/t5/arcgis-survey123-blog/survey123-tricks-of-the-trade-groups-grids-and/b...
GregoireCatineau
