Change name of a Connection?
715
04-30-2021 01:37 PM
thinkstopthink
Brand new to Survey123 and have what may be a silly question. I'd like to rename a connection. Where is that name set?
Thanks!
thinkstopthink
Anyone?
DougBrowning
MVP Esteemed Contributor
What does connection mean?  Not sure what you mean need more info.
thinkstopthink
Hi Doug,
On the startup screen of Survey123 there is a button "Manage ArcGIS Connections." When you select that, you are taken to a list of your connections. I want to know where that name is set. See attached.
