Change Date to Text in Survey123 Feature Report
827
7
05-04-2023 08:28 AM
StevenHughes44
New Contributor II
I have built a feature report based on Survey123 data and need to change a date to text based on the year of the date.  If the date has a year of 9999, I want to replace the full date with text.  Is this something that is possible?
BarbaraWebster1
Hi @StevenHughes44,
You could do this by using a conditional report element and the format method to return the year.
For example:
${if (date1 |format:”YYYY”)==”9999”}
A year of 9999 was entered.
-Barbara
BarbaraWebster1
Hi @StevenHughes44,
For example:
-Barbara
StevenHughes44
New Contributor II
Thank you for your help on this.  When I use the element as written, I get an error stating the the end tag is unopened.  If I load the template without the end tag, the report does generate with the element result of this:
BarbaraWebster1
@StevenHughes44 Can you provide the report template and XLSForm you're using?
StevenHughes44
New Contributor II
I have attached the Word template for this feature report.
BarbaraWebster1
@StevenHughes44 Thanks for sending the template. It looks like you're missing a space after the "if".
StevenHughes44
New Contributor II
Adding the space has fixed the issue.  What would I need to update in the element so this is shows a date that is not equal to "9999"?
BarbaraWebster1
Glad that worked! The operator for not equals is '!='. There is also a table in the Survey123 Report template documentation that includes all the operators you can use for a conditional section.
