Change all Dashboard layers
689
03-26-2024 10:20 AM
RHammers
Hi all! I have a "template" dashboard that will be used repeatedly with different surveys in the near future. Each time I make a copy of the dashboard (by inserting new#id= in the URL), I have to manually change the layer for each gadget in the dashboard, which is very time consuming. Is there a way to change all them them at once? This would save me a lot of time. Thanks for any help!
DougBrowning
We do this a lot with map viewer using ArcGIS Online Assistant   https://ago-assistant.esri.com/ to hack the JSON.
I think it works for Dashboards a bit also but not sure.  Worth a look.
