We are experiencing a similar problem, the images are uploaded successfully and the survey is moved to sent items when they are one per feature class or related table. But When we try to submit a survey 3 images using a repeat, the progress of submitting a survey stops at uploading 1 out of 3 attachments, then the submission fails and there is a red exclamation mark that does not open or give any additional information about the error.
Here is what we are seeing in the error log, check the Highlighted parts
<15>1 2019-01-08T21:26:13Z <PC Name> Survey123forArcGIS 25264 - [AppStudio@11205 category="qml" function="buildUploadsList" filename="XFormFeatureService.qml" line="534"] qml: uploads list: [
"editId": 4,
"parentGlobalId": "{18EFA70F-5568-4362-8D97-05A5A04FB21F}",
"fieldName": "RPTBEFOREPHOTOS_image",
"fileName": "RPTBEFOREPHOTOS_image-094d2b8d7dc64891b28ae56c4c3e5c8e.png",
"keywords": "RPTBEFOREPHOTOS_image",
"description": "Attachment field=RPTBEFOREPHOTOS_image"
"editId": 4,
"parentGlobalId": "{DCB68C4F-2C88-4EB9-95A3-47E944D643CE}",
"fileName": "RPTBEFOREPHOTOS_image-5187e0be8b5e425c955bc139a0701f09.jpg",
"editId": 4,
"parentGlobalId": "{412C2FD4-15DD-4760-9572-591FDCDF0EA7}",
"fileName": "RPTBEFOREPHOTOS_image-77fb652c4d4b470dba2bee3d5ad62c9f.jpg",
<15>1 2019-01-08T21:26:13Z <PC Name> Survey123forArcGIS 25264 - [AppStudio@11205 category="qml" function="uploadItem" filename="XFormFeatureService.qml" line="618"] qml: uploading: {
"description": "Attachment field=RPTBEFOREPHOTOS_image",
"file": "@C:/Users/<username>/ArcGIS/My Survey Attachments/RPTBEFOREPHOTOS_image-094d2b8d7dc64891b28ae56c4c3e5c8e.png"
<15>1 2019-01-08T21:26:13Z <PC Name> Survey123forArcGIS 25264 - [AppStudio@11205 category="default"] void __thiscall NetworkRequest::sendFormData(const class QMap<class QString,class QVariant> &,const class QMap<class QString,class QVariant> &) param "C:/Users/<username>/ArcGIS/My Survey Attachments/RPTBEFOREPHOTOS_image-094d2b8d7dc64891b28ae56c4c3e5c8e.png"
<15>1 2019-01-08T21:26:13Z <PC Name> Survey123forArcGIS 25264 - [AppStudio@11205 category="default"] void __thiscall NetworkRequest::sendFormData(const class QMap<class QString,class QVariant> &,const class QMap<class QString,class QVariant> &) Skipping Parameter "C:/Users/<username>/ArcGIS/My Survey Attachments/RPTBEFOREPHOTOS_image-094d2b8d7dc64891b28ae56c4c3e5c8e.png"
<15>1 2019-01-08T21:26:13Z <PC Name> Survey123forArcGIS 25264 - [AppStudio@11205 category="ArcGIS.AppFramework.Network"] ArcGIS.AppFramework.Network: void __thiscall NetworkRequest::setErrorCode(int) 0
<10>1 2019-01-08T21:26:13Z <PC Name> Survey123forArcGIS 25264 - [AppStudio@11205 category="qml" function="onErrorTextChanged" filename="PortalRequest.qml" line="75"] qml: portalRequest: https://utility.arcgis.com/usrsvcs/servers/<featureurl>FeatureServer/uploads/upload error
<15>1 2019-01-08T21:26:15Z <PC Name> Survey123forArcGIS 25264 - [AppStudio@11205 category="ArcGIS.AppFramework.Network"] ArcGIS.AppFramework.Network: void __thiscall NetworkRequest::setErrorCode(int) 401
<15>1 2019-01-08T21:26:15Z <PC Name> Survey123forArcGIS 25264 - [AppStudio@11205 category="ArcGIS.AppFramework.Network"] ArcGIS.AppFramework.Network: void __thiscall NetworkRequest::onFinished(class QNetworkReply *) url: QUrl("https://utility.arcgis.com/usrsvcs/servers/<featureurl>FeatureServer/uploads/upload")
<15>1 2019-01-08T21:26:15Z <PC Name> Survey123forArcGIS 25264 - [AppStudio@11205 category="ArcGIS.AppFramework.Network"] ArcGIS.AppFramework.Network: void __thiscall NetworkRequest::onFinished(class QNetworkReply *) systemProxy: (NoProxy """:0" ["Tunnel Listen UDP SctpTunnel SctpListen"])
<15>1 2019-01-08T21:26:15Z <PC Name> Survey123forArcGIS 25264 - [AppStudio@11205 category="ArcGIS.AppFramework.Network"] ArcGIS.AppFramework.Network: void __thiscall NetworkRequest::setErrorText(const class QString &) "Error transferring https://utility.arcgis.com/usrsvcs/servers/<featureurl>FeatureServer/uploads/upload - server replied: Server Error"
<10>1 2019-01-08T21:26:15Z <PC Name> Survey123forArcGIS 25264 - [AppStudio@11205 category="qml" function="onErrorTextChanged" filename="PortalRequest.qml" line="75"] qml: portalRequest: https://utility.arcgis.com/usrsvcs/servers/<featureurl>FeatureServer/uploads/upload error Error transferring https://utility.arcgis.com/usrsvcs/servers/<featureurl>FeatureServer/uploads/upload - server replied: Server Error
<15>1 2019-01-08T21:26:15Z <PC Name> Survey123forArcGIS 25264 - [AppStudio@11205 category="ArcGIS.Runtime.Utility"] ArcGIS.Runtime.Utility: class QVariant __cdecl JsonUtility::toVariant(const class QByteArray &,bool) Error: 5 "illegal value" Offset: 1 json: "<!DOCTYPE HTML PUBLIC \"-//W3C//DTD HTML 4.01//EN\" \"http://www.w3.org/TR/html4/strict.dtd\">\n\n\n<html>\n<head>\n<title>HTTP ERROR 500</title>\n<body>\n\n<h3>HTTP ERROR 500</h3>\n<p>Internal Server Error<p>\n\n</body>\n\n</head>\n</html>\n"
<10>1 2019-01-08T21:26:15Z <PC Name> Survey123forArcGIS 25264 - [AppStudio@11205 category="qml" function="onReadyStateChanged" filename="PortalRequest.qml" line="64"] qml: PortalRequest status: 500 500 Server Error
<10>1 2019-01-08T21:26:15Z <PC Name> Survey123forArcGIS 25264 - [AppStudio@11205 category="qml" function="onFailed" filename="PortalRequest.qml" line="79"] qml: PortalRequest failed: url https://utility.arcgis.com/usrsvcs/servers/<featureurl>FeatureServer/uploads/upload error {
"code": 500,
"message": "500 Server Error"
<15>1 2019-01-08T21:26:15Z <PC Name> Survey123forArcGIS 25264 - [AppStudio@11205 category="qml" function="onFailed" filename="XFormFeatureService.qml" line="592"] qml: upload error: {}
<15>1 2019-01-08T21:26:15Z <PC Name> Survey123forArcGIS 25264 - [AppStudio@11205 category="qml" function="onFailed" filename="SubmitSurveysPage.qml" line="351"] qml: Feature service error: undefined
O.O.
