Cannot read property 'name' of undefined
1289
03-06-2019 03:06 PM
Guest001
Survey submission hangs and the green wheel spins without stop when attempting to update related table
Survey123 logging error:
cannot read property 'name' of undefined
attached are the log notes, FS JSON txt file and the survey form folder contents
James Tedrick have you come across this type of error before? is there something we are doing incorrectly?
ArcGIS Online Environment, Points and tables were designed in Pro, Relationships were Parent GlobalID to Child GUID
Any help would be greatly appreciated.
JohnathanHasthorpe
Hi - Moving the now() function from the defaults column to the calculate column and republishing should fix this.
