BUG??? Join Layer Views preventing data schema from being updated in source layer.
238
07-24-2024 03:29 PM
BryceHancock
I have a Survey123 form I added a select one field too and attempted to publish the form through Survey123 connect. The form hangs on adding field 1 with no error message. I have checked the iteminfo file and the item number is correct. I did create a joined view of the data two days ago, but deleted both of those layers. When I go into AGOL and open the feature service, attempt to add a field on the backend, the add field option is missing. I have attached the log file when I sync and it says schema changes not allowed. There are over a 1500 consequential records in this feature service, so need to come up with a solution that maintains the data.
BryceHancock
Problem solved itself. After logging in today I was able to add a field and publish my Survey123 connect form. There seems to be a lag when changes are made to a feature service and for them to take effect. I have noticed this with 3 different operations this week. I am assuming it was after I deleted the dependent join layers from the recycle bin, and it just took a few minutes for changes to take effect and allow schema changes to the feature service again.
BryceHancock
Issue happened again today. Two hours since deleting the joined view layers and still cannot edit the data schema. Is there a workaround for this?
