Can you round the Image Direction Number in the Watermark (S123)?
1245
07-07-2020 09:45 AM
Peters_Amy
My watermark is working great using the bind::esri:parameters column using this statement: bottomRightWatermark="Photographed on: @[datetime:d MMM yyyy HH:mm] \n At: @[latitude longitude] \n Direction in Degrees: @[direction]&color=yellow&outlineColor=black&haloColor=white&size=32&bold=true&margin=10".  However, the photo direction shows way too many numbers after the decimal point.  Is there a simple way to round this number directly in the bind::esri:parameters column statement?
Thank you!
BrettStokes
Hi Amy,
I think this is just a duplicate post but thought I'd just make sure that you've seen Phil's response to this question in your other post (Can you round the Image Direction Number in the Watermark (S123)? )?
Brett
Peters_Amy
Thanks so much Brett!  Yes, I accidentally duplicated it and couldn't delete it.  I responded to Phil in the other post. You can delete this one for me if that's possible.  Thx.
