Can you open survey123 app to fill out repeated information in field maps?
413
08-04-2025 10:10 AM
EmilySpeck
New to using repeats. I have a survey set up that we are using survey123 for food inspections. There is a set of questions that is information related to the business including geopoint, and then i made a set of repeated questions for the inspection. How can I link survey123 to open in Field Maps to fill out the repeats?
ChristopherCounsell
MVP Frequent Contributor
  • In survey123 connect create a survey from an existing feature service
  • Remove the rows containing questions for the parent table, and the two begin/end repeat rows
  • Add a parentglobalidid question (to populate via url integration)
  • Add a form_id of the target repeat table in the settings sheet
  • Setup an url on your map to launch the survey from the pop-up and pass through the GlobalID into the parentglobalid field
Here's a (very old) video explaining it about 40min in:
https://youtu.be/vECznnoJHGk?si=jGuLQiwrQ2eLrVDa
While a lot has changed, the fundamentals should be largely similar.
Click here for more advanced ArcGIS Survery123 training: http://p.ctx.ly/r/9f6u This session provides a deep dive into authoring forms with ArcGIS Survey123 and discusses deployments of Survey123 for ArcGIS with your own ArcGIS for Server and Portal for ArcGIS.
ChristopherCounsell
EmilySpeck
how do you add a parentglobalid question to Connect?
ChristopherCounsell
Text, name is parentglobalid, field binding type ESRI guide
The field exists already
It's also in the video shared above
