Can you hide hints in survey 123?
1890
09-25-2017 09:16 AM
JeremyHooper
I have hints for many of my questions, however, at times they are quite long, so I would like set it up to where if the user wants to view the hints they can, but can also hide them.
JamesTedrick
Esri Esteemed Contributor
Hi Jeremey,
You can't hide just the hint component of a question.  If you have extensive instructions, they may be better placed in the survey as a note that is either above or below the question - it could then be placed into a group to all expand/collapse functionality or associated with a relevant statement so the it could hide after a value has been input or a checkbox unchecked.
