Can't delete records in nested repeat
3204
6
06-13-2021 11:13 PM
Hussam_AlJabri
Hi Fellas.
I can't understand why the nested repeats responses don't deleted once I delete their parents rows in the survey123 website. Also, I can't delete them manually from the related table.
the only way I  can delete them by using Pro.
Any advise?
using ArcGIS Enterprise 10.8.1
JamesTedrick
Esri Esteemed Contributor
Hi @Hussam_AlJabri ,
Was the feature service you are submitting data to created by Survey123 Connect?  If so, it should be using a composite relationship type, which will delete the related records.  You can confirm the relatioship type by opening the service URL for the feature service, clicking on the 'All Layers and Tables' link, and then viewing the JSON version of that page.
I am seeing that the tables for related records are not being updated after deletion on the Survey123 data page; manually refreshing the data removes the deleted records.
Hussam_AlJabri
Hi James,
The survey was created by Survey123 Connect. The relationship type is composite.
"relationships": [
   "id": 2,
   "name": "feeder_pillar_og_lv_feeders",
   "cardinality": "esriRelCardinalityOneToMany",
   "relatedTableId": 2,
   "role": "esriRelRoleDestination",
   "keyField": "parentrowid",
   "composite": true
the only normal repeat was deleted with the parents but the nested repeat wasn't.
Hussam_AlJabri
Hi @JamesTedrick
I'm still facing the issue and can't figure out the root of the issue.
JodyZhengLiu
This issue has been fixed and will be rolled out in our next 3.13 release in September. Would you please have a try then?
Jody Zheng Liu
Hussam_AlJabri
Hello @JodyZhengLiu and @JamesTedrick ,
I'm still facing the same issue with the published Form with version 3.14 and having a simple related table not nested.
Jared-Hall-CFW
Has anyone found a solution to this? I am having the same problem.
