Can Pulldata geopoint pull lat/long in dms
1533
04-19-2023 08:07 AM
NatalieSlayden
Hi, does anyone know if the pulldata function for geopoint in Survey123 can pull lat and long in dms rather than just decimal degrees?
ZacharySutherby
Hello @NatalieSlayden
You can use pulldata("@geopoint", ${location}, "DMS") to return the geopoint as degrees, minutes, and seconds. This function returns a JSON object so that can be parsed in two ways:
You can extract specific attributes using the following syntax ex. pulldata("@geopoint", ${location}, "DMS.latitudeText") returns "39°57'36.3\"N" for example.
You can also use pulldata("@json") if you want to separate the calculations.
Please see the Coordinate format section of the Geopoints documentation for more information.
Thank you,
Zach
ZacharySutherby
Thank you,
Zach
NatalieSlayden
Thank you Zach!! Extremely helpful!
