Can OR be used in the Survey 123 constraint field?
1580
06-01-2018 07:08 AM
AliciaRitzenthaler
Can OR be used in the Survey 123 constraint field in order to prevent the response to one question being the same as the response to other questions?
I have the survey questions 'Select the most abundant', 'Select the 2nd most abundant', and 'Select the 3rd most abundant'. I'd like to constrain the response to the 2nd and 3rd most abundant questions so that users cannot choose a response they selected for the previous question.
.!=${mostabundant} seems to prevent the 2nd most abundant response from being the same as the most abundant answer.
.!=${mostabundant} or .!=${2ndabundant} however does not achieve the desired response; the 3rd most abundant can be the same as either the most or 2nd most abundant answer.
CarmelConnolly
Hi Alicia,
Have you tried using 'and' instead of 'or'? 'and' tends to be more restrictive than 'or'.
Carmel
AliciaRitzenthaler
No luck with 'and' either unfortunately.
CarmelConnolly
Hi Alicia,
Attached is the form I tried with - I can't submit a form if an answer for Q3 has been selected in the previous questions.
Are you able to upload your form?
Carmel
