Can I view previously published surveys?
181
02-24-2025 12:15 PM
choenig
Is there a way to view the data collected from a previously published survey? I created a Survey in 2022, published it, and collected data. Then, I assume (I can't quite remember...) I edited the survey in Survey123 Connect and republished it. I can only find last year's data not the 22 or 23 data. I've looked on Survey123 Connect and arcgis.com and can't find anything. Is it lost forever?
@DougBrowning
DavidPike
MVP Notable Contributor
If you can't find the Survey in the 123 website or the hosted feature layer in ArcGIS Online then it's likely you've republished the survey at some point and made changes which required the hosted feature layer to be recreated (along with the loss of your data - things such as renaming fields and field types etc.).
I'd certainly just check through all your content in ArcGIS Online again (also the survey may have changed owner - so someone with admin rights should do a keyword search on organisational content also).
