camera settings flash
1195
10-25-2016 12:42 PM
DfIRivers
Is there a way to adjust the camera settings used within the Survey123 app so that it automatically uses the device's in built flash. E.g. if doing survey at night the camera 'captures image' but doesn't invoke the flash, so end up with black image (even when Camera app has flash set to 'on'). (Device used is Iphone).
PhilipMcLaughlin
Workaround: Survey123 has the ability to load a photo from the Gallery on your iPhone. You can take a photo using the normal Camera app on your device with the flash settings and then choose that photo from within Survey123.
