I am trying to call Collector via a survey in Survey123 to collect polygons and lines. Attached is a document (old screenshots) with the detailed process as well as my spreadsheet, but following is an overview of the steps I took:
So, I'm still at square one with no way to relate my line and polygon data to my original survey.
Somebody please take pity on me and tell me what I am missing!
Hi Whitney,
The extra lines in settings are not needed, though that should not cause an error on export. In your link to open Collector, I don't see you specifying the parentglobalid as per GitHub - Esri/collector-integration: Multi Language repository that contains documentation and sampl... . You would need to have that in the URL for the value to be prepopulated.
Thanks for the response, James
I had tried to pass the globalid from the survey to parentglobalid in Collector, but could not get the syntax right, I'm assuming, as it never worked. I reported that in another post. The link you pointed me to unfortunately only covers how to pass a static value, not a value from a field. I tried the following URL encoded syntax, which was unsuccessful.:
&featureAttributes=%7B%22parentglobalid%22:globalid%7D
I would be very curious to know how to do this correctly! I found an article which indicated how to do so going to survey123, but the same syntax does not work when going to Collector.
Hi Whitney,
This would be difficult to support currently in Survey123 as there is not direct access to the globalid of the form submission; the globalid is also not populated until the feature is submitted (so it may only work in Inbox scenarios).
Like I mentioned before I would try to stop using glocalids and use your own PrimaryKey in a text field and pass that. This will all get much easier.
The only way I know to create a unique id is by creating a GUID field. I did that and it still doesn't pass to Collector. Following is the syntax I'm using - is my syntax wrong? If so, please suggest the correct syntax! parentglobalid is the field name in the polygon fc being collected via Collector and UniqueSurveyID is the field in the survey.
<a href="arcgis-collector://?itemID=9f23ea7ae9bd4456b5c9d522a1ce6e4c&featureSourceURL=https://services.arcgis.com/EVsTT4nNRCwmHNyb/arcgis/rest/services/Source_Features_Collector/FeatureServer/2&featureAttributes=%7B%22parentglobalid%22:UniqueSurveyID%7D">Map a Polygon</a>
