Calculating elapsed minutes between entered time and now() using survey on browser (not app)
498
09-11-2025 11:05 AM
LS-SD
I am trying to calculate the number of minutes between a time that a user enters on a form and the current time. Not the elapsed time to complete the form.
This formula works when testing in Survey123 Connect: round(int(now() - ${StartedForm}) div (1000*60),1) but when the survey is published and used in browser, the # of minutes is blank.
Using the app is not an option, must use browser.
Thanks in advance for your help!
Neal_t_k
Honored Contributor
Looks like you are using EPOCH time,  that doesn't work on the web. Convert that calculation to decimal date and it should work on Connect/Field App and Web.
https://community.esri.com/t5/arcgis-survey123-blog/dates-and-time-in-survey123/ba-p/895528
Neal_t_k
Honored Contributor
LS-SD
Thank you Neal. Got it working with this calculation:
int((decimal-date-time(now()) - decimal-date-time(${wait_time})) * 24 * 60 )
