Calculate sum of value in different repeats
772
12-06-2021 08:58 AM
kelin84
Hi, I don't understand this. I think I've been trying everything at this point, but I guess I did not.
I have multiple repeats, which all creates a value for Example costs. That could be in a grocery store, where we can choose fruits and fish. Under that we have a level with types, that could be bananas, apples, salmon etc.
All have a value of the weight. I want to calculate the total  weight of all the groceries. I can get this to work with connect, but not in web.
This seems to work in connect:
coalesce(sum(${weight_1}), 0) + coalesce(sum(${weight_2}), 0)+ coalesce(sum(${weight_3}), 0)
But the field is blanc in web.
I then tried to add the raw calculations in 3 fields like:
sum(${weight_1})
sum(${weight_2})
sum(${weight_3})
And added to a more simple version:
sum(${weight_1})+sum(${weight_2})+sum(${weight_3})
That actually seemed to work, when I did the first testing also in web, but when I hided and added more calculations to it, or maybe it was since I used multiple calcualtions in the same category, it again didn't calculated the sum.
Any idea how to create this?
Thanks
by Anonymous User
Not applicable
Hi @kelin84,
We have made some updates in the 3.14 beta builds of Connect/field which will support calculationModes and better calculations and expressions when using repeats and the indexed-repeat function. This may help with you case.
These new enhancements and fixes can be tested in the latest 3.14 beta builds available on EAC later today.
https://earlyadopter.esri.com/project/home.html?cap=e69ef91f45744b98882c651f7b518eb7
Regards,
Phil.
kelin84
Hi, thank you Philip, that will for sure make it more intuitive in the future. I'm not going to test it now, since I found a working solution. Which I'll write below 🙂
kelin84
Most often, you I just need to check the samples.
Now I can't find which one it was, but with the use of Javascript:
function smartsum(...values) {
var total = 0;
for (var value of values) {
if (isFinite(value)) {
total += Number(value);
return total;
And then calculation in the Spreadsheet will work:
pulldata("@javascript", "functions.js", "smartsum", ${number1}, ${number2})
This one can jut be extended...
