Calculate field from 2 forms
646
07-09-2020 08:10 AM
ReneAubut
Hi. We have 2 forms, one for truck load description at loading site, and a second form at disposal site. Date and time are automatically captured in both. Is it possible to calculate travel time by having a calculated field in the destination form which would search the matching record in the loading site form to calculate time difference
DougBrowning
MVP Esteemed Contributor
No you cannot look across forms on the device.  If you will be online then some people have been using javascript pulls against the hosted feature service.  I have never tried as I am always offline.
You could do it in the web map using Arcade however, which I think is a better approach.  This will not work in Collector yet as FeatureSet is not yet working for lookups - but it should be this year.
Another option is to launch from Collector and push the pickup form date to the disposal form.  You could also add a URL to the first form that opens the second form and pushes the date and time.  (You could open from Outbox or Sent box)
Hope that helps.
