Basemap switcher in s123
1097
01-17-2020 11:17 AM
by Anonymous User
Not applicable
Using both s123 3.6 and 3.7.60 I am unable to utilize the basemap switcherfor any published surveys that I have edited in Survey123 Online.
I have tried using the standard (beta) and basic map types, re-installing s123 and re-downloading the surveys. Survey123 for ArcGIS
Map does not populateSwitcher screen shows blank
Tags (1)
JamesTedrick
Esri Esteemed Contributor
Hi Rebecca,
Just to check, the workflow you are describing is:
1) Create and publish a form via the Survey123 website
2) Open the form in Survey123 Connect and proceed to the Map Settings
Is that correct?  I was able to do that successfully for a test survey.
by Anonymous User
Not applicable
Hi James,
Thanks for your speedy reply.
3) Re-publish form from S123 online (we were changing the submission language)
4) Open the form in Survey123 Connect and proceed to the Map settings.
JamesTedrick
Hi Rebecca,
At step 3, what are you referring to by S123 Online - the Survey123 website or Survey123 Connect?
by Anonymous User
Not applicable
Hi James,
In step 3 I re-published the survey from https://survey123.arcgis.com/ after changing the Thank You Screen message under the Survey Design tab.
JamesTedrick
Hi Rebecca,
Thanks for the added detail.  I'm still not seeing the behavior you are describing - the maps are working normally for me.
