Barcode with a Feature Service
593
08-23-2018 11:54 AM
deleted-user-8TVt6oc0ewsX
Is there a way I can use a barcode with a "Feature Service" based form?  I want to scan a barcode and pull up the record in the Feature Service that has the barcode value and show it on the map.  I assume I cannot use PULLDATA() with Feature Services, correct?  Is there another way?
JamesTedrick
Esri Esteemed Contributor
