Barcode Scanner not working for EUIs
1466
12-20-2021 12:00 PM
abureaux
MVP Frequent Contributor
Hello,
Wondering if anyone has any experience with EUIs. These two are not recognized by S123. I tried many different zooms, angles, etc. and got nothing. However, the top QR-style code is detected by the default QR scanner built into my Samsung S8 near instantly.
Shwu-jingJeng
Hi Abureaux,
Could you provide some further information about this EUI format for us to look into the issue?
abureaux
Sure thing. What specific information would be helpful?
These codes are used on air monitoring equipment. This is one of the models: https://store.rakwireless.com/products/rak7204-lpwan-environmental-node
Shwu-jingJeng
Hi Abureaux,
Thanks for reporting the issue. I had logged an internal issue for this barcode scanner performance problem. Survey123 should support both QR cdoe and Code 93 barcode types and I was able to repro the performance issue with the latest version of Survey123 field app.
I would also encourage you to contact Esri Support Service to log a salesforce enhancement request so that you can track the status of issue fix.
