Automatic Put Thousand Separator When User Inputs an Integer or a Decimal
1392
04-03-2024 08:22 PM
jantolihao
Hello, everyone!
Here's my Survey123 form concern. The user wants to input a number (e.g 1000) in a field, say, Field 1. How can the form automatically put a thousand separator in the same field when a number is entered?
I am having trouble with dependency cycle error when putting a regex () function in the Calculate column of Field 1. The goal is for the user to input an integer or decimal in Field 1 then the form will just automatically insert a thousand separator based on the inputted value and displays it in the same field. I was also able to check the thousand-sep appearance, but this is only applicable for prepopulated answers, not by inputting. Is this possible?
Thank you for any hints/ideas regarding this concern.
abureaux
MVP Frequent Contributor
Sorry, but I believe the answer here is "that is not possible at this time"
