Autofill field 2 based on the selection in field 1 using ArcGIS Survey123 Online
502
07-25-2024 12:54 PM
RobertCorkren
Really, Really new to this, but I'm building a simple survey form, and I would like when the user inputs a species into field 1, then field 2 auto populates with the growth habit. Can this be done, or do I need to use a dsktop version?
Robert
ChristopherCounsell
MVP Regular Contributor
The method to do this is the formula pulldata() with a CSV lookup table to get the values.
I don't believe this is supported in the web designer, you need to use connect.
You could build the survey in web designer then download into connect to add the formula and CSV, but once you do you will need to continue to use Connect.
Personally I would recommend just learning Connect if you're going to be working in this space a lot. There's a lot of things you'll learn about good survey design that's not at the front of the web designer. If you're not, and you're confident this is the only survey you'll ever make, I'd stay in web designer, keep the survey simple, and do calculations like this AFTER the data has been collected. E.g. using pro, field calculator, joins...
ANH
I agree with @ChristopherCounsell. Here are some links to help you on your way:
  1. Download Survey123 Connect: https://doc.arcgis.com/en/survey123/get-started/installsurvey123.htm
  2. A tutorial for getting up and running with making edits in ArcGIS Connect: https://www.youtube.com/watch?v=NWn4lgoc85g
    Essentially, you can control and edit survey functionality through an Excel file. eg: Adding fields, setting string length limits, adding formulas to calculate one field from another. (See next point.)
  3. Formulas for field population: https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformformulas.htm
