auto-populate the answer from one field to other field in Survey123
2812
03-05-2019 01:51 PM
DiegoLlamas
Hello, I am trying to auto-populate one the answer that the user selected  from region, municipality and district fields to a second region, municipality and district fields. in my survey I got Region, District and municipality as select one
And I want to put the same answer the user selected to a second fields. I was trying using Put option i found in some geonet link but did not worked I got an error " SyntaxError: Expected token `,' in expression: put /AEE_Luminarias/municipality"
How can I accomplish  this?
Regards,
Diego Llamas
James Tedrick
DougBrowning
MVP Esteemed Contributor
Just do ${FieldName} in the calculation column  no put needed
ahagopian_coj
Hello!  I know this post is a bit old but I tried this and my 2nd field is always empty.  It won't populate from the data of the first field.  I put it in the calculate field the following:  ${firstfield}
I have read through everything and can't figure out what I am doing wrong.
by Anonymous User
Not applicable
Hi Diego,
"put" is not a supported xlsform expression. All you need to do is reference the questions name as ${region}.
Phil.
