Hello, I am trying to auto-populate one the answer that the user selected from region, municipality and district fields to a second region, municipality and district fields. in my survey I got Region, District and municipality as select one
And I want to put the same answer the user selected to a second fields. I was trying using Put option i found in some geonet link but did not worked I got an error " SyntaxError: Expected token `,' in expression: put /AEE_Luminarias/municipality"
How can I accomplish this?
Regards,
Diego Llamas
Just do ${FieldName} in the calculation column no put needed
Hello! I know this post is a bit old but I tried this and my 2nd field is always empty. It won't populate from the data of the first field. I put it in the calculate field the following: ${firstfield}
I have read through everything and can't figure out what I am doing wrong.
Hi Diego,
"put" is not a supported xlsform expression. All you need to do is reference the questions name as ${region}.
Phil.
