Auto-populate "Other" choice in ranking question based on fill in text response in Multiple Select
548
02-13-2025 10:32 AM
AmyAlford
In Survey123Connect, I have a question that is a select_multiple. There is an option for "Other" which I have added a text type question with a relevant condition if "Other" was selected.
Now, I want users to rank the choices they selected from the select_multiple question. I have successfully completed that by including :selected(${list_multiple}, name) as a filter constraint such that ONLY their choices appear in rank question. However, I would also like the "Other" text they entered to be populated in the rank question. Right now, it just displays as "Other" as "Other" is listed as a choice in the select_multiple question.
Is this possible? Do I need to add another question or do I need to add some other filter or appearance constraint?
Added an example
DavidSolari
MVP Regular Contributor
Even if you're able to get that Other value into the Rank question, you have to deal with sanitizing the answer so that it's a valid identifier and it'll most likely break the rank display when viewed online. You're best off leaving that rank choice as "Other" and using the "choice_filter" column to only show "Other" if there's a valid answer — you can use this blog post as a reference. For the future you can plead your case in this idea and maybe something will happen.
DavidSolari
AmyAlford
Thanks, I'll just keep it as it now with "Other" in the rank question.
