I have appended old survey results to the new survey results; the schema is exactly the same; however, when generating reports from the old results, attachments are not displayed, but they are there. How do I resolve this?
I have attchached
1.How results are displayed for both old and new results. Old not displaying which i guees could be the issue.
2. The icon shown on the report instead of photos.
Kindly assit.
Musandiwa Sadiki
Hi @MusandiwaSadiki ,
That makes sense.
For the report syntax,
So in ${attached item | size:250:0}, "attachment item" is invalid syntax.
To print the image in its original size, you can just use the syntax without specifying its size: ${$file} in an iteration or ${image1} for the specific question. Please note that the original image size probably exceeds the width of the document, that's why we usually use the "size:<width>:<height>" method to control its size.
The form view on the Data page of the Survey123 website and the Survey123 report service can display attachments for an image question as long as there is a `keyword` property of the attachment written with the same image question name. Otherwise, we cannot know which question an attachment belongs to.
From your description, https://support.esri.com/en-us/knowledge-base/how-to-update-the-attachment-keywords-for-existing-arc... might help you add the keyword property for attachments in old records.
Thank you very for the response, the syntax that has worked is the one detailed below.
${#$attachment}
${$file}
${#attachments}
${/attachments}
${attached item | size:250:0} failed, when I removed it, however the attachments are displayed partially. Which syntax above can I use to display the original size of the photos?
That makes sense.
Thank you very much, it has worked so perfect, have even generated survey reports.
