ArcGIS Enterprise_Report_API_Images
915
06-22-2021 04:54 PM
FranciscoAndrade1
Hello, I was wondering if there is an update in regards to the Report API and adding images to the report.
We are currently on ArcGIS Enterprise(Portal) 10.6.1.
We have created a script to call our feature service that is in our Portal and use the report api to create the report but the image does not get added to the report.
We have been using this same script to call feature services that are on AGOL and the script works perfect and images are added to the report. We are only experencing this issue in our Portal.
ZacharySutherby
Hello @FranciscoAndrade1
Survey123 requires attachment keywords in order to associate what attachment maps to what image question in the survey. Prior to ArcGIS Enterprise 10.8.1 attachment keywords weren't supported on attachments leading to the issue observed where images don't come through when creating reports as Survey123 does not know what images are associated with what question.
This issue has been resolved in ArcGIS Enterprise 10.8.1 and newer as attachment keywords are supported in those versions.
Please use this link for reference regarding how to update the attachment keywords in ArcGIS Enterprise: https://support.esri.com/en/technical-article/000024606
We also have a Python notebook that will automate the process in our Survey123-tools GitHub repo that can be used after the 10.8.1 or later upgrade.
Thank you,
Zach
Thank you,
Zach
