Adding URL Scheme Hyperlink in Survey123 to open another Survey
5212
02-06-2017 02:28 PM
TL2
I would like to included the URL Scheme hyperlinks within a survey in order to toggle to other surveys, in a way mimicking subforms.  Is there a way to include a clickable hyperlink in a form?
JamesTedrick
Esri Esteemed Contributor
Hi Tucker,
You can embed the urls as notes if it's a static link to simply open the form.  Survey123 currently doesn't support dynamic generation of the links (for example, including form data from one link to another)  There are a few user experience issues with this approach though:
- Users will be leaving the original form partly completed when moving to the next form and may forget to complete/submit the original form
- Users will need to have all forms downloaded if this is a low connectivity/disconnected environment
There will also be a possible data management issue of linking the surveys together through informal relationships (vs. relationship classes with parent / repeats).
by Anonymous User
Not applicable
Hi James Tedrick‌ has there been any functionality added in regard to dynamic link generation?
JamesTedrick
Hi Chris,
It is now technically possible to create a dynamic link (using the concat() function), but the user experience issues mentioned above would still present a practical problem to using a link in this manner.
Apple
Anyway you can link multiple surveys together without experiencing the issues posted about in 2017?
