I have created a custom template to produce a feature report, and every field referenced is working as expected other than the photo field. I believe I've used the proper syntax for the photo field, and have changed the width multiple times trying to get it to fit, but am still not having any luck. I put the syntax in a text box, or just floating in the document with no luck. Is there something specific I need to do to the word template to get the photo to appear?
Karim
Hi Karim,
Are you using ArcGIS Online or are you in an Enterprise environment? What happens when you generate a default template for the survey and attempt to use that for a report (default should contain photo with default syntax)? One suggestion would be to try to remove the spaces in between the vertical bar (i.e. ${photoofmissingperson|size:100:0}
Best,
Brandon
Thanks for the quick response Brandon. this is coming off of a hosted dataset. I generated the default template and that is where i got the syntax with the spaces before and after the pipe. Using the default template, it works as I would expect. I think I'll try to start from scratch on the template and see if I get the same outcome.
Karim
Karim Naguib Thank you for the additional information. If it remains an issue after redesigning the template, please let us know.
