Adding domains to a web designer based survey?
1040
09-11-2019 10:42 PM
JeremyWolff
I was hoping that I could add domains through the feature layer in ArcGIS online (Data, fields, edit List of Values (Domains)).
My goal is to be able to download a excel file which would have the correct names for our database directly from the feature layer in ArcGIS online or from (data, export) in Survey123 web.
From here I would just need to add domains such as scientific names for our database and get rid of the symbol underscore ( _ ) that appears in the excel table when downloaded.
I thought that this could be done from the feature layer in ArcGIS online but they still don't display correctly.
Would anyone know how I could get rid of this underscore (_) in the species name or how to add domains that stick?
Thank you
Jeremy
Tags (1)
JamesTedrick
Esri Esteemed Contributor
Hi Jeremy,
You could add the domain manually via the Item Details page for the feature layer - you would need to add a list.  See Define attribute lists and ranges—ArcGIS Online Help | ArcGIS for more information.
Kevin_MacLeod
Hi @JamesTedrick , do you know when Esri will add this capability to Survey123 Web Designer?  My top request for Web edition would be to point it to a CSV of domain choices on AGOL to use for a pick list.
