Adding a thumbnail using Survey123 web designer
9991
20
03-15-2018 08:18 AM
ShaneClarke
Is there a way to use Survey123 web designer to add a thumbnail so that it displays in the Survey123 apps? Or do I HAVE to use Survey123 Connect? I hope not!!
TimothyKing3
Hi I had this issue as well. I found out that if there are any spaces in the file name Survey 123 Thumbnail.jpg and I used it it would work until I updated the 123 form.  If you remove the spaces it will stick.  So Survey123Thumbnail.jpg should work.
