Adding a Map with Selectable Points in Survey123 Connect
2427
10-05-2023 10:50 AM
tjenkinsvdcr
I'm new to using Survey123 Connect to build public-facing surveys. I'm looking to understand if there's functionality where I can add a question that asks the survey taker to "select a point" from a layer on a map and provide an answer that references that point. The map would have pre-existing point data from a hosted layer, survey takers would select one of those points, and provide information about the condition for example. Is this possible?
Thank you!
DevarsiMajumder
yes in the general online survey builder  there is  a question with location  info where you can select that question and it will make the person enter their location on a  map.  In  survey connect you can add this question also.
tjenkinsvdcr
Hi DevarsiMajumder -- thank you for responding! I don't mean the survey-taker's location, but instead wanting them to select a point from a pre-determined group of points that will already be on the map (from a hosted layer that I created). Does that make sense?
SarahRijneke
