Adding a Decimal
2498
7
02-02-2022 09:33 AM
ToddHill
I'm hoping someone can point me in the right direction to add a decimal point in my last calculation. I have attached a screen shot of the calculation and the result on the form. I have also attached the XLSForm. All the calculations work perfectly except I need a decimal point after the first number. So instead of a result of 588, the result needs to be 5.88.
I have read through some of the post on decimals but unfortunately I didn't had any luck.
Thanks for any help in advance,
Todd Hill
DougBrowning
MVP Esteemed Contributor
You are using int() in your calcs.  Integers have no decimal points so it is removing them.  Just remove the int() since all your fields are decimal anyways it is not needed.
JayantaPoddar
As rightly mentioned by Doug, you may remove int() function, or replace it by number() function.
Also you might want to further multiply the expression by 0.01 in case you want to get 5.88 instead of 588.0 (as per your example screenshot.
Think Location
ToddHill
So when I add another 0.01 to the calc the answer came in as a 6.
I attached a picture.
Thoughts?
ToddHill
So I made the change you both suggested and I got the result I'm looking for but without the decimal point after the 5.
Can either one of you tell me how the calculation should be to get the decimal point added?
See the attached screenshot of the XLS and the Form.
Thanks again for your help,
Todd
JayantaPoddar
number(0.785 * ${D1} * ${D2} * ${PL} * 7.48 * 50 div ${cl2s} * 0.01 * 0.01)
Think Location
AndyMcClary
Also it looks like the field type for your gal field is integer. If you change that to decimal that should fix your problem.
JayantaPoddar
You are right.
Initially (in XLSFORM), it was mentioned as Decimal, so I overlooked on that part.
Think Location
