Add constraint comparing another field and NULL
3053
05-14-2019 05:14 PM
DamianMilne
Hi, I have two integer fields, "FIELD A" and "FIELD B". I am trying to add a constraint on "Field A"  that meets the following conditions:
If "Field B" IS NULL, "Field A" can be any value (including NULL)
If "Field B" IS NOT NULL, "Field A" must be greater than "Field B"
Can anyone assist with the syntax please?
Regards, Damian
DougBrowning
MVP Esteemed Contributor
You just want it to eval to true so just give it a 1.
if(string-length(${Field_B}) > 0,${Field_A} > ${Field_B},1)
DougBrowning
In 123 Null is empty string.  So compare to '' or "".
JamesTedrick
Esri Esteemed Contributor
Adding on to Doug's comment, use the function string-length(${q}) > 0 to test for null - all question types evaluate to a string length of 0 when null.
DamianMilne
Thank you gents, however the answer still alludes me. The closest I can come up with is the following:
if(string-length(${Field_B}) > 0,${Field_A} > ${Field_B},*** any number or NULL ***)
Any further assistance would be greatly appreciated.
DougBrowning
DamianMilne
Ahh, many thanks Doug.
